Old 01-17-2008, 08:47 AM
crazythoughts crazythoughts is offline
Post Swapping Air Conditioner System
Hi. I have these old 1985 and 1986 Mitsubishi Lancers. They are both of the same exact model. The problem is, the 1986 car had its airconditioner parts replaced sometime back with reconditioned parts after some problems. And its is not as good in the sense that it takes very long to cool and the air is not very cold. After many visits to various air conditioner workshops, it appears that this problem is because of the cheaper parts that were put in.
Now I will be selling off my 1985 car which has really very good aircond.
My question is:
I want to swap the parts from the old car to the newer car. What are the parts that needs to be swapped? (Not by myself but the workshop) I am willing to refill the gas for both cars and pay for the wokmanship.
P.S. In my country there is no law against doing such things. And these are old cars that don't have any fancy electronic controlled stuff. It does not even have fuel injection. So I think this should not be a very difficult task.
Old 01-17-2008, 12:36 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Swapping Air Conditioner System
depends on what the actual problem is with the AC system. If you wanted to swap everything over, it would be very labor intensive. The evaporator is usually in the dash and requires it to be completely dissassembled
IMO, you should get the AC system diagnosed by someone that knows what they are doing. "problem is because of the cheaper parts that were put in." is a very vague diagnoses.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-18-2008, 02:02 AM
ok.
But what part determines the "coldness" of the air and which part determines the amount/volume of air?
I changed the condenser, condenser fan, compressor, and dryer. I thought these are the only parts that affects how cold the air would be. What other parts are there?
Old 01-18-2008, 12:04 PM
AF -Advisor
Originally Posted by crazythoughts
ok.
if any part fails in the system, it will cause it to not perform correctly. If there's a leak in the system, it doen't matter how well the components work.
