Old 01-17-2008, 07:40 AM
silveradofirerescu silveradofirerescu is offline
Turn Signal Trouble
Hey all, I just want to confirm that the flasher for my turn signal is bad. The left signal will stick and not blink where as the right one will. When I put on the hazard flashers, they do not flash as well. Any other suggestions other than the flasher, I would greatly appreciate it. You could save me a some time and headache if you told me where the flasher was and which one to buy from (insert local auto store here). Thanks in advance!
Old 01-17-2008, 10:20 AM
Re: Turn Signal Trouble
ok, so new development. When i press on the brakes I get my parking lights on... and when my headlights are off my turn signals blink but so do my headlights. I am afraid this is indicative of a BCM but i wanted your opinion before I took it somewhere. Thanks, Derek
Old 01-17-2008, 04:09 PM
knogoodidleft knogoodidleft is offline
yeah your truck must of been made on a friday.
Why did Jesus walk everywhere?
Because he drove a ford
Old 01-17-2008, 06:57 PM
rjeffery rjeffery is offline
Sounds like it needs to be exorcised.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 01-17-2008, 09:14 PM
lol, i just chalked it up to its a chevy. I was wondering if it could be a short in the towing harness? or maybe in the taillight harness'? how would i check that if it was? thanks, derek
Old 01-18-2008, 06:17 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
I had some weird stuff happen with my lights...plus I had whiffs of smoke coming from the steering column. It turned out to be the turn signal unit. It was interesting to replace since both Chiltons and Haynes use the same picture and both point to the wrong bolts to take out. The part is expensive from the dealer and there are several on eBay that are not factory but probably work fine. I found and bought a used one.
Old 01-18-2008, 10:20 AM
I am guessing there is a short somewhere. I can no longer drive it at night as my brake lights are on constantly with my parking lights. Is there a way I can diagonose a turn signal unit? thanks for the help, Derek
Old 01-18-2008, 12:40 PM
gremlin96 gremlin96 is offline
start by cleaning all grounds to the frame. battery to frame, motor to frame, frame to dog house. tail lights to frame. remove any add on trailer light harness. check all the lights on the truck. check the wires from the plug to the tail lights. confirm the plug is working fine no grit or grime inside.
then from there keep working back untill you find the fult.
Old 01-19-2008, 05:26 PM
Well it turned out to be easier than I could have imagined. It turned out to be a trailer light harness had corroded and shorted causing all the trouble. I just unplugged it, cleaned it and plugged it back in, 5 minutes once I found it. Thanks for all the help, once again!
Old 01-19-2008, 10:38 PM
muff34 muff34 is offline
had a similar wiring issue with an s- 10 I owned . step on the brakes and front markers would come on, popped the fuse (can`t remember which one .) turned out to be a bulb 1157 had gone bad . one element broke and crossed over to other element. what job finding that,truck was only 3 years old. friggin electrical can make you pull your hair out...lol
Life Is A Highway ,Enjoy The Ride
