Old 01-17-2008, 01:42 AM
van24 van24 is offline
99 Blazer-Squeaks going over every little bump
I'm not sure if it is shocks, suspension or something else.
Old 01-17-2008, 12:33 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 Blazer-Squeaks going over every little bump
You need to get under there and have a look and feel for the noise.
Have a helper shake it up and down and see if you can feel where the noise is coming from.
Good luck
MT
MT
Old 01-17-2008, 12:54 PM
drdd's Avatar
drdd drdd is offline
Have you greased all zerk fittings in the suspension with a grease gun?
You might also try some silicone lube spray on your control arm bushings and sway bar bushings.
Do your shocks have fluid leaking down the side?
Old 02-01-2008, 08:44 AM
Omek Omek is offline
I know this thread is a few weeks old but if ya come back and check,
the Upper ball joints will make it squeek like a bunch of ratz figting over a drumstick in an alley.
I find that those "lube shops" ignore the upper ball joints even when you ask them to lube all the grease fittings.
So I started not taking my vehicle to shops at all.
Cost me less money overall but more headaches.
Have not decided which is the lesser of two evils.
