Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-16-2008, 08:55 PM
mountie1982's Avatar
mountie1982 mountie1982 is offline
tranny help needed!!!!!!!!!
Driving home tonight after turning right on to my street the tranny didnt shift into 2nd. Tranny stays in first will not shift up. Rev works like a charm. When I shift from park to a drive gear in clicks right in like it should. Any ideas? The ses (i think thats what its called on the dash) has not come on. Fluid seems fine and is full. Was shifting fine a few minutes before this.
2001 1500 4x4 175,000 km
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
Old 01-22-2008, 12:14 PM
rockwood84 rockwood84 is offline
Re: tranny help needed!!!!!!!!!
time for the tranny shop..............
Old 01-22-2008, 11:17 PM
yea its going in on thrusday
1964 Vw Baja 1600
Old 01-23-2008, 11:52 AM
probably the bands came off or something broke to happen that quick.
Old 01-23-2008, 06:12 PM
dcx96 dcx96 is offline
hang on. try replacing the input output sensor its easy and on the side of tranny.
Old 01-23-2008, 10:44 PM
Input output sensor? Ill take a look in into this. Any more information aout this sensor would be a huge help.
1964 Vw Baja 1600
Old 01-24-2008, 03:46 PM
this sensor is what tells the tranny to shift not much more to say . it just unclips and then unscrews and goes in the same way, careful tranny fluid will come out.
Old 01-28-2008, 01:28 PM
Moser97 Moser97 is offline
Check the throttle valve cable running from the throttle linkage down to the trans too. If this broke or came off it will affect this 1-2 shift. Some of the Rams have the speed sensor on the rear end pumpkin, and I think some have both rear end and trans sensors.
'06 Honda Accord
'02 Chevy Tracker SS - only SS you'll see, 2L, 5 speed
'97 Ram 1500, 5.2, 2wd, 46RE
Old 01-30-2008, 08:04 PM
turns out I still had an extended warrenty so Dodge repair it. Snap ring inside was broken and valve govenor was toast.
1964 Vw Baja 1600
