Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-16-2008, 08:23 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
04 Ram 1500 4x4
I am working on a 04 Ram 1500, the BRAKE light on the dash was flashing, I looked in the owners manual and it says the light will flash when the parking brake is set. Well the Parking brake is not set, So I check the abs system for codes and got a code 37 - intermittent signal from rear speed sensor.
Ok so I checked for a loose connection or corrosion at the connector and didn't find anything so I replaced it along with the brakes and rotors all the way around. After I got it done, The BRAKE light was still on (not flashing tho) and now the ABS light was on as well and the speedometer is bouncing around up to 20 mph without the truck running just with the key ON, and if you leave it on long enough you can see the odometer changes as well.
Has anyone heard or seen this before.
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 01-16-2008, 08:28 PM
Re: 04 Ram 1500 4x4
oo yea and I understand the ABS light prolly came on because the speedometer is saying the truck is doing 20 mph but the wheels are not moving.
Old 01-17-2008, 04:34 PM
Re: 04 Ram 1500 4x4
Well the problem was water in the plug on the ABS CONTROL MODULE, I also replaced the Rear Sensor again and it is all working fine again, no light no funky speedometer.
Old 01-22-2008, 11:38 AM
rockwood84 rockwood84 is offline
Re: 04 Ram 1500 4x4
water where it ain't supposed to be will weird things up every time
