Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-16-2008, 08:14 PM
tdg038 tdg038 is offline
Check Engine Light Code P0455
1999 GM
Need help getting this repaired, it is supposed to be "evaporative emission control system leak detected". Anybody have any idea what this is, O'Reilly's does not list a part.
Any Suggestions would be greatly appreciated.
Old 01-16-2008, 08:59 PM
reekor reekor is offline
Re: Check Engine Light Code P0455
It can be may things, start with the most common problem, replace the gas cap.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-31-2008, 01:21 PM
Any other ideas, changed gass cap and reset CEL. Went for a day and now back on.
Thanks,
Old 01-31-2008, 04:31 PM
P0455 code means that you have an EVAP leak. You can check the CV solenoid, EVAP canister and purge valve, fuel filler neck, fuel vapor control valve, fuel vapor return lines. If you do not find any problems with these items you will need to find a shop with a smoke machine and have them trace the problem for you, as this is not always a problem that can be easy to find by eye.
Thanks,
