Old 01-16-2008, 05:09 PM
gflum gflum is offline
no headlamps-97 silverado
Headlights started going off when tilt wheel was activated. They would come on if the tilt was in the up position, off if the tilt was down. Now they won't come on at all. Just running lights. Any ideas?
Old 01-16-2008, 05:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: no headlamps-97 silverado
Welcome to AF!
A '97 should be in the C/K forum. That said, it sounds like a wiring problem. The light switch is on the dash on yours? Try wiggling the wires in the steering column and under the dash, if the headlights come on you'll need a wiring diagram to find which wires to check. It could also possibly be a bad hi-lo beam switch, they turn off the low beams when the high beams are turned on. It could be pressed in just far enough to turn off the low beams, but not turn on the hi beams. On my truck, there is a very small gap that is noticable if I pull the lever slow enough.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-16-2008, 06:22 PM
777stickman 777stickman is offline
Sure sounds like a wiring problem in the column. The wire that powers the dimmer switch is yellow. If you get into it that's the one to look for.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-18-2008, 10:26 PM
dcmaynard dcmaynard is offline
I am a little lost. He has a 97 Chevy Silverado and your telling him he needs to be in the CK forum. so your saying that I need to be there too since I have a 97 silverado and this is a silverado forum? could you please explain?
Old 01-18-2008, 11:07 PM
rjeffery rjeffery is offline
Technically, the "Silverado" forum is for 99 and up model year trucks and the "C/K" forum is for all prior years. Posting in the correct forum increases your chances of recieving accurate responses.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
