Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 01-16-2008, 03:27 PM
kjones226 kjones226 is offline
Send a message via AIM to kjones226
Exclamation '96 Sc 2.4l
Hi! My '96 SC 2.4L is having some issues. I started the car today and it seemed kind of quiet for once...the I realized that the heating/air will not turn on at all. After I drove for a bit (I left it on, just in case) I turned it off again and it made a wheezing noise like it was on and then off. I don't know what's wrong with it, but I need my defrost! Also, I need new tired and when I get them I can get my alignment done for free, BUT, the control are is a bit funky...would the control arm trash the new tires even after I get the car aligned? THANK YOU!!!
*ugh, It's 2.4 not 2.1, Sorry!!
Old 02-08-2008, 08:06 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: '96 Sc 2.4l
on the heat check the fuses.
if the blower isnt working check the fuse for that too.
If hte fuses are good then your blower or resistor are bad.
hope that helps
1999 Grand Am SS 3.4 OHV
Old 02-13-2008, 07:57 PM
Re: '96 Sc 2.4l
Hey, I just wanted finish this up. The car needed a new fuel pump/sending unit. And now it needs a new blower motor...after that it should be all right. Thanks for the help!!
Old 03-27-2008, 12:40 AM
okmech1 okmech1 is offline
Re: '96 Sc 2.4l
kjones, I didn't see your post before I posted my own question about the blower motor. Seems like we have a similar problem, could you let me know how the blower motor change was? Thanks
Old 03-27-2008, 01:08 PM
Re: '96 Sc 2.4l
Actually, after we changed all of the spark plugs and put in a new O2 sensor the car has been running great! The blower is working much better, so now the windows just need to be fixed because the can't roll up or down without "derailing" lol, I hope you work things out with your Unda-Achieva...
Old 03-27-2008, 08:09 PM
Re: '96 Sc 2.4l
Good deal! New plugs in mine did a world of good too. I had to put new valve cover gaskets on to stop the oil leaking out, and aside from the usual quirks familiar to most achievas, it's been a good car
2001 Honda Passport 3.2L V6, all stock - 90K
2009 Toyota Matrix - 10K
