Old 01-16-2008, 03:01 PM
IFallsRon IFallsRon is offline
88 Sliverado electrical flicker
In the morning my headlights flicker and the charge indicator needle bobs up and down for 30 to 90 seconds as if the alternator has gone bad. After the said time everthing seems to go back to normal.
The alternator is around six months old and shows no problems on a bench test. The battery test good, too.
I've cleaned the battery cables and tracked cables and wires to where the appear to be securely connected.
Old 01-16-2008, 03:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 88 Sliverado electrical flicker
Did you check the battery? A severely undercharged, or bad battery can cause voltage fluctuations of several volts.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-16-2008, 03:53 PM
jasont26's Avatar
jasont26 jasont26 is offline
Send a message via Yahoo to jasont26
A bench test dont always tell if the alternator is good or bad . when you first start your truck the alternator is working its hardist to recharge the battery and maby failing under extream load. maby you need to get the high output alternator to make up for it...
