Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-16-2008, 12:20 PM
Brian Beverage Brian Beverage is offline
Full time 4x4 front knuckles and Crankshaft Sensor
Ok I know 4x4 makes steering a little difficult but when I have to turn sharp I of course slow WAAAAAAY down, but when I turn it sounds awful! Are there grease serts on the front knuckles or could the joints be bad?
Also Where is the Crankshaft sensor located, and how do i test functionality?
1997 Jeep Grand Cherokee Limited
Full Time Quadra Trac
4.0 InLine 6
178,000 Miles
Old 01-16-2008, 03:01 PM
legalfee legalfee is offline
Re: Full time 4x4 front knuckles and Crankshaft Sensor
The first thing I'd do is check the front end oil. If you replace it use synthetic oil.
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 01-16-2008, 03:26 PM
As in the front differential oil?
Replace with Lucas maybe?
4.0 InLine 6
178,000 Miles
Old 01-16-2008, 08:15 PM
reekor reekor is offline
Your front wheels shouldn't bind when making sharp turns. Your Quadra-Trac transfer case should only lock into 4wd when your rear wheels start to slip/spin and when they do have traction the case should be in 2WD mode and take sharp turns as well as a RWD car. This is common vicious coupler failure of the Quadra-Trac case. In the long run it eats up your front tires and universal joints, not to mention the poor gas mileage.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-17-2008, 03:41 PM
Is this a thing that is happening in te transfer case?
Would this explain my difficulty shifting to low-range?
When I try to shift to low range I put it in neutral, shift quickly from full time 4 high straight back to 4 low. I wait then when I shift into gear (either Drive or 1st) It will sometimes catch then when I give it throttle it will pop the 4x4 selector forward slightly and grind horribly, without moving. ????
4.0 InLine 6
178,000 Miles
