Old 01-16-2008, 05:40 AM
flashlight flashlight is offline
Why so Long
When I go to heat my car up it seems like it takes forever to get hot. I have flushed the heater core and changed out the coolant.What should I do to increase the speed of heat output in my car?
Old 01-16-2008, 06:05 AM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
Re: Why so Long
Thermostat
Old 01-17-2008, 09:30 AM
brivers brivers is offline
Re: Why so Long
How long are you talking about? Mine takes about ten to fifteen minutes. Can't expect to much out of our little 3 bangers.
Old 01-17-2008, 10:16 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Re: Why so Long
My '93 - 3 banger takes a good 5 minutes to get warm. It's a motorcycle engine!
I have a new Thermostat, too! a 185° one.
If your Metro has over 100,000 miles, why not replace the thermostat just as a
matter of course.
It is right up there near the Distributor and is easy to get at. Costs $5.
It will give you peace of mind.....
DoctorBill
Old 01-17-2008, 03:02 PM
Hugemoth Hugemoth is offline
Re: Why so Long
My 1.3L takes 15 minutes before it'll put out much heat. Just so happens that my commute is 15 minutes long so its a cold ride to work. A $20 heated seat cover works real nice.
Q
Old 01-21-2008, 11:40 PM
wetback1 wetback1 is offline
Re: Why so Long
I'd certainly do the thermostat first. Then, depending on your climate, start with a full sheet of cardboard across the rad - if the engine tends to heat too much just fold down or cut off 4 or 6 inches at a time until you find the right balance. This worked well for me on the prairies with both 3 cyl Geos and 4 cyl Dodge Colts.
Now I live on the west coast and after a 2-3 min warmup in the driveway the car is up to full temp within 3 minutes - but I start off to work on a slight grade which makes things work a bit harder.
