Old 01-15-2008, 08:20 PM
BuckWild75 BuckWild75 is offline
No traction control
My car got stuck in my driveway after a snow storm, and after some wheel spinning it got out. But now my ABS/ Service engine soon/ PCM/Traction off lights are now on and I don't got any traction control and maybe ABS. Has anyone heard or experienced this and if so is there any sites where I can order a traction control/ABS module. Thx
Old 01-15-2008, 09:47 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: No traction control
you mean your ABS, Service Vehicle Soon, PCS, and Trac Off lights.
But at any rate, I would start by checking the wiring to all 4 wheel speed sensors, basically check the wiring that runs into the back of the hub assembly, and make sure that the wiring harness are still clipped onto their hangers, being buried in the snow may have dislodged a thing or two.
Also, I highly doubt it is your ABS module causing this problem, unfortunately in order to retrieve those codes you will have to either go to the dealership or a good mechanic, expect labor charges from both. I would guess its most likely a failed wheel speed sensor, or it could just be some damaged wiring.
The most common components that fail in the system are the wheel speed sensors, the ABS,TCS, and PCS systems all use those sensors, so if theres a problem, all of the systems fail.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 01-16-2008, 08:38 PM
Thx alot. I will certainly check that out and hope its just a simple fix. Buy the way your ride sound pretty nice, all I have done to mine is audio upgrade with 12inch subs and a indash dvd.
