Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-15-2008, 07:07 PM
SkitzMcQueen SkitzMcQueen is offline
Question 1990 mustang covert top motor problem
I have a 1990 mustang convertable, 2.3 auto, i was told the convertable top was working intermitent and when i got the car it did not work at all, someone had been in there (haha) i rewired it with the original relays, switch and motor according to all the ford diagrams i could find, i also used mitchell mechanical diagrams(own it) and it will not work. Now if i wire in one relay only i can make the top go up or down depending on the side you hook up, when you try to wire the relays together the way ford wants all the relays do is click, the relays, the switch and the motor all test fine on a bench test. the double relay setup is straight from ford but i cannot figure out why my relays will not switch ground and power back and forth any ideas or suggestions would be greatly appreciated.....p.s..i fix them for a living and this is the first one that has stumped both my father and I.
Old 01-16-2008, 11:35 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: 1990 mustang covert top motor problem
Sounds like the switch is faulty. Switch may test ok, but have you tested under voltage load?
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
