Old 01-15-2008, 04:50 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Timing chain tensioner
I have a '98 G/A with the 2.4l. It has a bad timing chain tensioner which bleeds down after about an hour. After starting it, it rattles a bit then smoothes out after a few seconds. I don't know if it's my imagination, but it seems like it actually runs rough for the first couple seconds, like the valve timing is off. I'm almost entirely certain that the tensioner is on the "loose" side of the chain, but I wanted to get a second opinion on whether or not I can wait until spring to replace the tensioner.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-15-2008, 05:02 PM
brian 1 brian 1 is offline
Re: Timing chain tensioner
my opinion I would not wait.the tenisioner runs off oil pressure,thats why the noise goes away after it runs,builds pressure.plus with the guides on the timing chain should keep the slack out of the chain.if the tensioner bleeds down to much it will make the chain and guide rattle.if the tensioner bleeds off to much could cause the chain to skip a tooth.
Old 01-16-2008, 04:37 PM
J-Ri's Avatar
Thanks, that's what I was thinking... it's just so damn cold
