Old 01-15-2008, 11:46 AM
jasont26's Avatar
jasont26 jasont26 is offline
Send a message via Yahoo to jasont26
Exclamation 91 pk with no power to the fuel pump
i have a 91 chevy 6 cylinder with no power to the fuel pump i checked the fuse and relay and both are good. If i jumper the relay to start it, it will stay running when i pull the jumper but will not start. I need to know what controles the fule pump relay
Old 01-15-2008, 04:27 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 91 pk with no power to the fuel pump
There is an input to the relay from the PCM. The PCM will supply either power or ground, I can't remember for sure which. Check for voltage/ground with a voltmeter. A test light will draw more current than the circuit is designed for.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-15-2008, 04:42 PM
jasont26's Avatar
Question Re: 91 pk with no power to the fuel pump
i did use a test light and found no voltage there from the pcm. I will re check it with a dvm, do you think i did any damage??
Old 01-15-2008, 04:46 PM
J-Ri's Avatar
It's possible... probably not likely for just a short test period, It's just better to be safe. A relay has about 80 ohms resistance, a test light has around 3 ohms. And if it isn't supplying power, there was no harm done.
Old 01-15-2008, 04:53 PM
jasont26's Avatar
so with no power there am i looking at a new pcm??
Old 01-16-2008, 05:05 PM
J-Ri's Avatar
Not necessarily. First, check for power to the wire off the PCM, there could be an open in the wire somewhere. Also, make sure you have power to the PCM from the ignition switch. You probably do if it runs jumpered, but I try to check everything I can.
Old 01-23-2008, 12:15 PM
jasont26's Avatar
just a update i changed the oil pressure sending unit and it runs without the jumper but it starts hard and i dont hear the fuel pump prime. i found a wireing diagram and there is a few places the power comes from for the fule pump relay. the hot fuel modual and the fule primer module i need to find them and check them. thanks for the help
