Old 01-15-2008, 04:42 AM
G.A.S. G.A.S. is offline
service engine light
I finally got a service engine light, whoo hoo,.
How do I read the code on this vehical.
1999 chevy ZR2 blazer.
I understand there is a way to jump a lead under the dash.
could someone fill me in on where it is and how to do this please.
thanks in advance
Old 01-15-2008, 05:24 AM
gmctruck06 gmctruck06 is offline
Re: service engine light
You can't jumper the leads on a 96' ( not sure of the cut off year) or newer vehicle. You'll need to take it to the dealer or some parts shops will hook up a scan tool and read your codes for you as well.
Old 01-15-2008, 06:02 AM
16th hippy 16th hippy is offline
96 is when it was mandatory for OBD II compliance, but some manufacturers were totally/semi compliant is 95, a couple even in 94. either way, with a 99 model, you will need to use a scan tool. the local autozone will scan it for free, just don't let them tell you this is the part you need. GET THE CODES...lol. and then post them here.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-15-2008, 06:11 AM
thank you very kindly, its on my adjenda for today and I will post back.
Old 01-15-2008, 09:36 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Do not let them sell you a bunch of parts to go with the free code check.
Just get code and Post code no back for help with it.
What is the mileage or how long since last tune up?
MT
MT
Old 01-25-2008, 11:12 AM
finally got to get the code scanned.
It is a P0404 whitch doesnt help me out as this is a EVAP Emissions control malfunction.
in other words a loose gas cap.
I have an intermitent missfire and was hoping that the code would tell me something.
It runs fine when going down the road but when you take off it misses.
I did have this problem once and it was moisture in the cap.
Bad too. I think it got in there from the underbody washes but cant be sure.
When I find the time I will pop the cap off and see what I can fine there.
Old 01-25-2008, 12:16 PM
MT-2500's Avatar
AF - Advisor
How many miles on tune up stuff?
Ac delco plugs?
Good wires?
Make sure fuel pressure is up to par.
You may need to get it on a good engine capable scanner.
Check camshaft retard settings and fuel trims and missfire counters.
If it miss fires it will show up in history codes and give what cylinders are miss firing.
And check MAF sensor.
MT
