Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-15-2008, 02:40 AM
0-60IN2 0-60IN2 is offline
Head gasket
How much boost can I run safely on a stock head gasket? Will it hold up for a while?
Old 01-15-2008, 05:05 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Head gasket
Probably 14 psi range without issues arising any time soon.
2004 Mazda 6i
1997 Tahoe
Old 01-15-2008, 07:27 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Head gasket
I think it may be around 22-24psi. Not really sure though
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-15-2008, 07:30 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Head gasket
I thought it was around 10psi
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-15-2008, 07:37 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Head gasket
Depends what motor we are talkin about here... You've been here since November and still don't have a single spec or clue to what your car is in your sig.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 01-15-2008, 07:41 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Head gasket
Assuming we're talking 4g63T (which I think you have), I wouldn't run more than about 20 maximum on an older motor if you want to keep up the reliability. To be a little farther on the safe side, 18 seems like a good number to me.
On a side note, like Brian said, put at least the basics about your car in your sig. Year, model, trim, tranny, and if you want, a modlist too. That way we can better help you in the future by eliminating confusion like posted above.
95 Talon TSI AWD
97 Eclipse GST
Old 01-15-2008, 01:25 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Head gasket
It depends entirely upon how well the car is tuned, what head bolts you have, and the current state of the headgasket. Being that I think you have a 2g (they have stretchier head bolts) I wouldnt push it past 14-15. If you have a 1g I thnk you can get away with 18-20. Regardless, I would throw some ARP's and a new(stock) headgasket before you tUrN uP dA mAd TyTe BoOsT.
Oh yeah, remember head gaskets fail from knock before they will from actual boost, provided the head bolts stay. In the case of the headbolts, higher cylinder pressures cause them to stretch, thus theres less compressive forces on the headgasket and the in blows out. If you want me to go into why head bolts strech I can, but I am not going to waste my time if no ones cares.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-16-2008, 03:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Head gasket
I ran 2g head bolts to high 20s or 30 psi. Same with the EVO, which runs the 2g stretchy bolts but a metal HG stock. A 1g uses regular head bolts. They're no ARPs, but they'll go to 30 psi too I'm sure. The stock 4g64t mitsu composite gasket held for me up to 35 psi on ARPs, running 30 psi regularly. If this parts are failing for at lower boost pressure you're fuckin up somewhere, IMO.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-16-2008, 10:19 PM
92talontsiawd 92talontsiawd is offline
Send a message via AIM to 92talontsiawd
Re: Head gasket
ok, so u can run mis 20's for psi if u put arp head bolts in the 4g63 motor? cause i have a 92 talon with the 1g turbo, and it has a brand new stock head and head gasket. so i was wondering if i could run mid 20's for psi if i get the arp head bolts? right now im runnin 19-20 with no problem.. let me know.. thnx
Old 01-16-2008, 10:29 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Head gasket
Read the post right above you and then kiss the ring.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 01-17-2008, 06:04 AM
Re: Head gasket
With ARPs you could easily run above 30+, at that point it depends much more on your supporting mods than the boost pressure.
95 Talon TSI AWD
97 Eclipse GST
Old 01-17-2008, 08:36 PM
Re: Head gasket
haha yea i should read that post better.. but thanx.. im just trying to find out all the info i can before i go and stall building up this motor.. cause im new to this dsm and turbo world.. i use to have a 88 chevy camaro, so this is new for me lol
Old 01-17-2008, 11:34 PM
Testiklees
Re: Head gasket
www.vfaq.com is your friend. Use it. Love it.
Tim
1990 Talon AWD
PTE SCM5031
