Old 01-15-2008, 12:20 AM
bigboi_408 bigboi_408 is offline
Unhappy Emergency Lights
The emergency lights go on all of a sudden
when im driving my car. If i just hit my stearing
wheel, the lights go on. They go on for exactly
1 min then turn off. Even if i kick my front rim the
lights go on. Its hella weird. We removed the
battery and when we conected it, the lights began to
go on. I tried everything to make it stop.
I checked all the fuses and the light never turned off.
I dont know if this is making any sense, but i'll try
putting up a video tomarrow so you can all see
what i mean.
Old 01-15-2008, 12:44 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Emergency Lights
Do you have an alarm? When did you get the car? Could there be one you havent seen in the car? Sounds like your setting it off but the siren isnt hooked up, especially if it does it when you kick the car, and if its for an exact set amount of time. And if you disc the battery. Otherwise the hazard lights are controlled by the hazard switch, and the turn signal relay. Without the hazard switch your turn signals will work but they blink crazy fast. Those are the two pieces to inspect, but if the signals and hazards work like normal I would search the wiring for an alarm.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-15-2008, 12:53 AM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
that sounds just like an alarm look for the brain and remove it
Old 01-16-2008, 10:01 AM
it was just the alarm.
my teacher didnt put the key in the on position
when he was connnecting the battery. i desconected
the battery and put the key in the on position
then connected back up and it wasnt doing that noise again.
Old 01-16-2008, 11:47 AM
FrodoGT's Avatar
Glad to hear you figured it out, AND that we were right..would hate to go digging through the car looking for "something"
Current project:
Rio Red 91 hatch.
