Old 01-14-2008, 08:05 PM
97accordExV6 97accordExV6 is offline
Cool Need HELP! 97 accord v6 ex RPMs fluctuating, speedometer works fine
Hello, this is the problem: My rpm tachometer does not work right. In the mornings the the rpms tachometer works fine, once the engine warms up or after a couple of drives the rpm tachometer stops working. Meaning it wont read or its just fluctuating from 0 to a lit over 1. The speedometer works fine.
Check engine light is the only thing that comes on. Got it scanned and it said P0725, vehicle speed sensor.
Found an answer to the problem in the following link: What do you think? could it be the ignition coil?
http://findarticles.com/p/articles/m...04/ai_n9079886
97 accord ex v6 automatic
Old 01-14-2008, 08:46 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: Need HELP! 97 accord v6 ex RPMs fluctuating, speedometer works fine
well according to what i just found by taking two minutes of my time id say that there where tons of recalls out for this vehicle some that have to do with the ignition switch but where im puzzled is that the tach measures rpms off the distributor commonly known as the blue wire coming out of the distributor and goes straight to the gauges so what i would do is check out this link for the recalls on your vehicle then do a search on this forum for service manuals and download the manual its the full service shop manual not some haynes or chilton manual im talkin 1200 pages big thats how big mine is so check it out it has detailed wiring diagrams all you have to have is adobe reader and have fun
http://www.automotiveforums.com/vbul...archid=2097987
well i was gonna make you search for it but i posted the link above
Old 01-15-2008, 12:09 AM
jgr7 jgr7 is offline
Read this thread , post number 4.
http://www.automotiveforums.com/vbul...trange+problem
Jeff
Old 01-19-2008, 01:44 PM
hey thanks wiseguy, did look into it and yea i know alot of recalls and the only good thing is that i havent had that much of a problem with car. except with the rpms. Did check the wires and everything seemed fine. so after reading both links i just decided to give the ignition coil a shot. Sure enough i changed it and RPMs are working fine. Am happy that it was an easy fix.
Thanks jeff for the link and wiseguy appreciate it
i would definetly pass on the tip to next person who might have the same problem on the forum, saves you time and money
Old 01-20-2008, 02:43 PM
Happy to help, that's what makes this and the other forums I'm involved with such a great resource. With all the experience out there it makes since to try to fix what you can before going to the dealer. Just remember to check the forums frequently so you might be able to help another person in need.
Jeff
