93 Jimmy Fan working no air coming through vents
so I have a 93 jimmy and all coolants etc have been topped up...i also noticed that ll my gauges work great and are all hovering around the mid point...also the fan is running the belt is fine and all that.....
question is: why isnt there air coming through the vents...no heat...vent.....defrost..nothing however the dash gets warm and the gauges are fine.. PLEASE HELP... |
Re: 93 Jimmy Fan working no air coming through vents
If you have plenty of hot air coming out of the defrost vent at the base of the windshield then your source of vacuum is suspect. If the fuel injection is a CPI (big sculpted runner intake manifold), the vacuum source is the fitting at the passenger side/rear of the intake manifold near the distributor....check to see if a vacuum line is connected there.
There is a vacuum-operated diaphragm that selects the mode (dash, floor, defrost, mix). When you move the dial/lever and all you hear is hissing, then you probably have a hole in the diaphragm and will have to replace it. Mine was ~$15 from the dealer.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
