Old 01-14-2008, 06:19 PM
himey7826 himey7826 is offline
'03 Sunfire Headlight Problem Solution
First Off just want to thank everyone that contributes to this site. It made my life a lot easier. I had a problem with my headlights not working. The daytime running lights and low-beams would not work. High beams were fine. When I went to put the car in drive from park, I could hear the DRL relay in the fuse box clicking. After reading many posts on this subject, I combined them to come up with the fix to my problem.
First off, there is a harness underneath the battery. It's about 3" long. the wires travel beside the inner-body and windshield washer container. I found a couple of wires there to have been rubbing against the steel, causing them to frey. I fixed those ones, re-taped them but still no headlights.
After reading some more, I found a thread to look at the wires running at the front of the car in front of the rad. I found that there was newer electrical tape on them, so I unwrapped it to find the one wire with a butt connector all corroded. The wire in my case was blue. I fixed that, re-taped and the problem was fixed.
These cars are apparently known for headlight switches breaking down on them too, but by doing some testing with a tester it can be ruled out.
Again I just want to thank everyone for the replies they give to posts, which really helps people out! Cheers!
Old 01-14-2008, 11:30 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: '03 Sunfire Headlight Problem Solution
Hmm, actually the older 95-97 range had a lot of issues with the headlight harnesses. might want to consider putting some wire loom around those wires so they don't rub anymore.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
