Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-14-2008, 02:38 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Can I swap my 350lb srpings to the rear and get some 600lbers for the front? (or 550)
First off... looking at the car it looks like the coilovers are the same on all 4 corners w/ the only difference being the spring rates. Assuming they're the same size etc I'd like to swap my 350 fronts to the rear and get new fronts... can I do that?
I checked the PNs and verified that I have 350 front springs and 200 rear... pretty darn soft.
Shold I get 550 front or 600? My buddy said that w/ a coil over all the sprnig pressure is gone once the car is in the air, so I can just remove the coil over, pop off the top retainer, and swap springs... easy peazy... yes?
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 01-14-2008, 04:10 PM
Soflow1's Avatar
Soflow1 Soflow1 is offline
Re: Can I swap my 350lb srpings to the rear and get some 600lbers for the front? (or 550)
Your buddy is right ,"yes" you can swap the springs from front to rear as easy as you described. However, I'm not sure the Koni shocks used on the GTRA will stand-up to the 550# spring rate.
I'm sure you realize after you've done this swap that the car's ride height will need to be reset and re-corner weighted on scales.
Old 01-14-2008, 10:27 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
I'm going to do the same thing. The suggestions I've been given by John (Panoz Lead Engr) and Gary Jones was to go to 550# up front and swap the 350# to the rear. That's where the Series cars start with springs. This might be soft as well, especially for smooth tracks.
I'm sourcing springs right now. My car has H&R springs. The P/N is R25100350 on the front and R25100200 on the rear.
Please let me know if you run into any trouble with the swap. I'll do the same.
Soflow1 is correct that the car will need to have it's ride height re-set and corner weights balanced (corner-to-corner) after this operation.
Jerry
1999 Panoz GT-RA
Old 01-14-2008, 11:05 PM
Cobra4B's Avatar
^ Yep I know... I'll most likely do it after my first NASA event end of February. I was curious about the Konis too... I was goning to get fresh Konis and do the spring chang-a-roo and ad a rear swaybar to dial in the car.
Brian B.
