Old 01-14-2008, 12:27 PM
Micah_Jones Micah_Jones is offline
Paint?
Sorry for the kinda dumb question, but where is a good place to buy paint for cars? I just want to repaint the rocker panels on my 91 stealth but im not sure where to find the replacement paint. Thanks in advance.
Old 01-14-2008, 01:54 PM
Pearl94GT Pearl94GT is offline
Re: Paint?
Automotivetouchup.com
Paintsratch.com
I used automotivetouchup.com because they had better prices.
THe quality was good, and the color was very close (pearl white-difficult to match perfect) and black. I used preval sprayers and had difficulty with consistent spray but it came out ok. You'll have better turnout if you use an actual sprayer...good luck...
Old 01-14-2008, 03:20 PM
Re: Paint?
well the only problem is i was hoping to not have to order online...would places like autozone or advanced have paint that would work? my paint code is s22/pvc...i dont know if its a very common color...its like a wheat beige kind of color...
Old 01-14-2008, 03:26 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Paint?
the only way youll get it not on the web is ordering it thru an autobody place. Parts stores only carry more common colors. Although i actually found a GM color that matches mine almost perfectly.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 01-14-2008, 09:41 PM
Re: Paint?
Hmm...so you dont think it is possible to find it at an auto parts store? and there is a rust hole that goes through the rocker panel...how should i patch that? its about the size of a baseball =/
Old 01-14-2008, 09:55 PM
Re: Paint?
well, the RIGHT way to do it is to get a torch or grinder and cut out the area in a nice square/rectangle section. Make sure you cut out ALL the rust. If you leave any it will spread like cancer. Then cut out a patch the same size from galvanized steel, and weld it in. Then, grind smooth the welds. Use body filler to make the lines perfect. Sand to perfection. Prime. Paint. Clearcoat. Wetsand (if neccesary), then buff.
Depending on where exactly it is, its not as hard as it sounds. If your not experienced with such things, it will take some time. I had never done ANY bodywork, and i managed to repaint a whole car in a week, including bodywork. (no holes to patch though, only some surface rust and smaller dents).
Formerly BlinkRA182
Old 01-14-2008, 10:19 PM
Re: Paint?
Yeah i know that would be the right way to do it, but the only problem is..i have no access to any sort of tools besides carpentry tools...so no torches/welders/etc...i was thinking i could just grind off all the rust but then im not sure what to do from there...how would i patch the hole without having access to a welder?
Old 01-14-2008, 11:06 PM
new2mitsu new2mitsu is offline
Re: Paint?
lol, you could be super cool and fiberglass it :P
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 01-14-2008, 11:34 PM
Re: Paint?
haha yeah right...theres no way i could do that without messing something up...but i was looking in a hardware stores newspaper ad and i saw a thing called a "pencil torch"...it says it heats up to like 2000 degrees and you can weld/braize with it...i was wondering if i bought one of those, do you think that would be able to secure a new piece of steel on to the body? im new to all of this stuff so i have no clue what works and what doesnt...
EDIT: heres a link to that pencil torch...its cheap so im thinking about asking to borrow my grams credit card to buy it =)
http://www.harborfreight.com/cpi/cta...emnumber=94185
Old 01-15-2008, 03:28 PM
Re: Paint?
i have one exactly like that, even from harbor frieght actually, and about the only thing i've been able to use it for is soldering... also, w/ the flame all the way up, you'll use tons of butane
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 01-16-2008, 01:08 AM
Re: Paint?
So does that mean you dont recommend trying it new2mitsu? what about the torch things that are at hardware stores that are like 20-30 bucks? i think they are powered by Mapp gas?
Old 01-16-2008, 01:17 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Paint?
Yes, please do it this way. Bondo/body filler is NOT for filling holes.
Depending on the color of your car you may want to take it somewhere. If it has pearl in it, it is VERY hard to match and lay evenly.
