Go Back   Automotive Forums Car Chat > Renault > Mégane
Old 01-14-2008, 09:04 AM
Den-C Den-C is offline
Angry Starting Problems
I'm having problems starting my Renault Megane 1.6 RT 1997 when cold the engine fires but won't run unless you apply light pressure to the accelerater and cuts out when you lift your foot. Once the engine has run for a few minutes and the turned off and left for a few minutes it will start OK but sometimes cuts out when you stop at a junction, Once at notmal temperature the revs somtimes drop right away when you pull up but it does keep running.
Old 04-08-2008, 03:41 PM
krishnadas krishnadas is offline
Re: Starting Problems
Hai, I have also the same problem for my renault megane 1.4 h/b 2000, It starts some times well ,when I go garage to tell about this then it starts well, no warning light on,battery and spark plugs are good ,pls help .
Old 03-06-2009, 04:51 PM
wooliepigs wooliepigs is offline
Hi. I have a Meggane Authentique 1.4 2001, the problem is very simular. I have full electrics, but when I turn the key the is no responds from the engine. The only way of starting the engine is to bump start the car. Have you any idea, I going to push it over a cliff soon.
Old 07-17-2009, 09:21 AM
riyafath riyafath is offline
Please check your starter motor connection. Sometimes these cars have loose connections with the sensors. After starting the car if you can drive smoothly, the fuel pump and the fuel injector is working. It is most probably the connection with the starter motor.
Old 07-17-2009, 09:27 AM
You need to change few things first. Sensors are not that much reliable for Megane. You need to change the Fuel filter, Fuel Injector. Expensive item is the fuel pump, but you might not need to change it. You also need to change the Crankshaft Position Sensor and Temperature Sensor - these two are located on the motor box.
Old 07-15-2014, 07:00 AM
Whizzy Whizzy is offline
I would check Idle control valve and TDC sensor (clean if dirty)
