Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-14-2008, 07:31 AM
matthewellis1 matthewellis1 is offline
which brand of spark plug - 2001 rodeo
I just changed the spark plugs in my rodeo yesterday - I bought autolite dbl platinums. This morning I have a check engine light on - should I have bought a different brand?????
Old 01-14-2008, 08:16 AM
Tom01Rodeo Tom01Rodeo is offline
Re: which brand of spark plug - 2001 rodeo
Yes, you should've used the Denso brand. The original number should be in your owner's manual. Some came factory with Champions (mine did), but the Denso's seem to work best. That seems to be the consensus around here, anyway.
Old 01-14-2008, 08:46 AM
very well - thanks so much
Old 01-14-2008, 11:46 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I've also heard of NGK iridium plugs working. Personally I prefer denso, they've always performed way better then any other plug for me.
The reason for certain plugs is that the ignition system on yours uses the plugs as a sensor. If you dont use the right plugs it will read wrong and you will get a misfire code.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
