Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-14-2008, 01:17 AM
RoadRunna RoadRunna is offline
91 caprice classic emmision problems
i have a 91 caprice and i failed my emissions test because i was giving out too much carbon. I was told that the coolant temp. sensor was critical and to check to see if the thermostat was stuck open. If it was running cold it would cause it to run too rich. well i changed the thermostat cause it was stuck open and i changed the sensor just because. if you have any suggestions please let me know, would like more info before i take another shot at the test.
thanks.
Old 01-14-2008, 10:19 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 91 caprice classic emmision problems
Make sure the air filter is clean, you have no vacuum leaks, the injectors are both spraying properly, and the distributor is timed correctly (should be TDC or 0 degrees TDC if I remember correctly).
The CTS is the #1 culprit in a CO failure on one of these TBI cars, however.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-14-2008, 05:45 PM
j cAT j cAT is offline
thanks.
check plugs for excessive fouling if carboned up replace. also pcv replace and if oil is dark and goopy replace after a week of driving it should run better after the carbon in the combustion chamber is blown out................
