Old 01-14-2008, 01:03 AM
Jaxx67 Jaxx67 is offline
Exclamation Grand Caravan going downhill ???
Ok, here's the situation.
I have a 96 Grand Caravan/3.3 liter/2WD
First of all, I have a problem that I have noticed is somewhat commonplace with GC's and Voyagers.. The instrument panel went dead. Now I have tried replacing the BCM, the instrument panel, and tried pulling the IOD fuse. None of these things worked (guages still flatlined) I have heard that the CCD may have some bearing on this problem. Where is the CCD located ? And is this a really expensive thing to fix ?
This problem started just after the alternator was replaced (if that means anything)
I have been dealing with this for a while now...
But recently, another problem has come about.... Whenever I let up on the accelerator, it makes a weird noise similar to an engine brake on a semi but not as loud, (I dont know how else to describe it, sorry) It does not make this noise when I accelerate... just when I let off the gas.
Other than these problems, the van runs well. I am just afraid that it may get worse.This is my only vehicle without which I would be hurt'n 4 certain !
Can anyone help shed some light on any of these problems ?
Thanks in advance. Any help/suggestions are appreciated
Old 01-14-2008, 02:30 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Grand Caravan going downhill ???
The CCD isn't a component. It is a data bus system (wires and IC chips) the electronics in the van use to transmit data on. http://www.freepatentsonline.com/4739323.html
Have you tried an instrument cluster calibration test? When the alternator was changed was the battery disconnected first? Not doing that can damage the PCM, a major player on the CCD bus.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-14-2008, 12:27 PM
Smile Re: Grand Caravan going downhill ???
I'm not sure if the battery was disconnected or not. I got the van from my sister. Her hubby changed it. I will have to call and ask.
Thanx for the reply.opcorn:
Old 01-15-2008, 10:59 AM
Stretch58 Stretch58 is offline
You said the Instrument panel was replaced, was it a new one or used?
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 01-15-2008, 01:18 PM
It was a used one from salvage yard... couldnt afford a new one.
Old 01-15-2008, 02:15 PM
Might have the same bad connection problem
see link:
http://www.ingriddijkers.com/CaravanPics.html
The bad Instrument panel problem has caused a lot of grief. If the connections on the one you put in were not originally bad, they might have cracked with the removal from the other car and re-installation.
The pictures show where to do the repair if you know about soldering.
Also make sure your battery is fully charged and not causing the problem.
Regards
Had Recently
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 01-17-2008, 11:51 PM
I will look into that. Thanks for the reply.
Any idea what the noise is when I let off the gas ? That has me boggled. And I hope it isnt something that is going to scrap my car if it isnt fixed right away.
