Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-13-2008, 11:48 PM
94HeavyChevy 94HeavyChevy is offline
Suspension
i have a 94 caprice with a 5.7L V8 and i want to lower it, give it a slightly raked look, and make it overall stiffer with not so much flex while cornering. ive seen a 1 inch lowering kit by hotchkins and a 2 inch lowering kit by sprint. i was thinkin of getting the 2 inch lowering springs for the front and the 1 inchers in the rear...what else could i do to stiffen the ride up...any suggestions would be appreciated
Old 01-14-2008, 12:13 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Suspension
Don't use lowering springs. If you want to remove height, keep the springs that you have and use lowering knuckles instead - this will retain the proper suspension geometry so that your handling and cornering does not go south.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-14-2008, 05:39 PM
j cAT j cAT is offline
Re: Suspension
last summer i reworked the front and rear stailizer bars used new bushings on front and in rear removed bar support cleaned up rust repainted and all this stiffed up vehicle on turns ......
Old 01-14-2008, 08:41 PM
Re: Suspension
what are lowering knuckles and where would could i find them?
Old 01-14-2008, 08:59 PM
CD Smalley CD Smalley is offline
Re: Suspension
I believe what you want to look for are lowering spindles.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-14-2008, 09:57 PM
Re: Suspension
ok i have never heard of the term knuckles before...i have seen 2 inch lowering spindles on some web sites...are drop spindles just for the front suspension?
