Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-13-2008, 10:59 PM
codencerence codencerence is offline
Motor Swap?
I have a 91 caprice with the 305. Would it be much more difficult swapping in a corvette engine then it would be the impala ss engine. I know they are the same engine but are all the electronics and everything about the same.
Old 01-13-2008, 11:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Motor Swap?
The iron head LT1 is actually a better fit for your car than the aluminum Vette head motor is, due to cam timings, etc.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-13-2008, 11:15 PM
evildragon evildragon is offline
Re: Motor Swap?
I just had an LT1 put in my 94 Caprice..
I so need to update my sig.. Though my motor swap involved a tranny swap too..
Power, so much more power!! XD (and gas usage )
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 01-22-2008, 06:49 PM
96_9c1 96_9c1 is offline
Re: Motor Swap?
It will be a very time consuming project.
If you do go for the lt1, the Caprice/wagons, roadmaster, Impala, Fleetwoods from 94-96 all have the same engine. Also the vette motor isnt as good as it sounds, the cam is made for a car much lighter than our 4400lbs beasts.
We need the tq down low to get moving. If you plan on doing a cam, the vette motor may not be a bad deal....DEPENDING ON PRICE
Old 01-22-2008, 06:59 PM
Re: Motor Swap?
Ehh, some 94 Caprice's have an L99, and not an LT1.
L99 Engine
Old 01-22-2008, 07:08 PM
Re: Motor Swap?
You are correct, and I could have said it better in my first response. But the point I was trying to make is that he/she can broaden there search to more than one car
And also, wagons have been know to have L99 in them, too
Old 01-22-2008, 09:02 PM
GreyGoose006 GreyGoose006 is offline
Re: Motor Swap?
personally, if i had more funds, id do a corvette motor with 4.11's and a six speed, but that wont be easy.
i doubt that the torque difference will make THAT big of a drivability issue unless you are really pushing it.
and the extra top end will surely help out for when you do...
Old 01-22-2008, 10:18 PM
mike561 mike561 is offline
Re: Motor Swap?
I found a local listing on craigslist, the posting was as shown: "350 Chevy engine 4 bolt main, runs good. $250 OBO" im still a beginner at all this, what is "4 bolt main"?
2006 Chevy Cobalt LS
Old 01-23-2008, 12:53 AM
silicon212's Avatar
Confoundingly Lucid
Re: Motor Swap?
On a '4 bolt main' block, the middle three main caps (2,3,4) have outer bolts as well as inner bolts. The outer bolts are about an inch or so shorter than the inner two bolts.
A two bolt block doesn't have these outer bolts.
The factory 4-bolt blocks might be a little stronger than two bolt blocks for high RPM use. If you're not going to spend considerable time over around 5500-6000 RPM, the two bolt block is strong enough.
Old 01-24-2008, 08:13 PM
Re: Motor Swap?
FYI the cam in the vette is meant for a car 1000 lbs lighter.
They make the same tq, but the tq curve is different.
The car will be more of a dog out of the hole...
Old 01-24-2008, 08:41 PM
Re: Motor Swap?
yes, but gearing can make up for it.
im a bit tired of people dogging the corvette engine.
not that i take it personally, but it still will outpreform any 305 and if someone has one, its a good motor and i'd put it in.
now given the choice, id go for a fuel injected towing ready 350, but we dont always get our first choice.
anyway
Old 01-25-2008, 07:30 PM
96capricemgr 96capricemgr is offline
Re: Motor Swap?
Actually with boltons and tuning the Vette and b-body motors make similar peak numbers. I have wondered if the Vette and f-body motors got weak lowend torue to try and save their relatively weak axles.
An L99 to LT1 swap is easy, a TBI to LT1 not so much.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 01-25-2008, 11:50 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Motor Swap?
A quick solution to eliminate the dogging off the line with a vette engine in a heavy car would be a high stall torque converter to get the engine closer to it's "power band" at lower vehicle speeds.
