Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-13-2008, 07:42 PM
vulcan_03 vulcan_03 is offline
rear signal light replacement
can someone tell me how to replace my drivers side rear signal light........I cant access through the trunnk and lost my owners manual....need help before I get a fine.........also have issue with reverse lights......have had switch for that replaced twice by dealers and its gone yet again......this is third year in a row.....getting fed up with this 200$ per year to safely back up..along with all other regular maintenance.....and of course when I mention to dealer that this is same issue as last time they come up with some God awful excuse for it not to be under warranty anymore.........
Old 01-18-2008, 09:18 AM
godsspeed godsspeed is offline
Re: rear signal light replacement
First we need to know what year/model you have.... but lookin in your profile im guessing its a 2000. is it the SE or GT?
I have a 99 but i think the 99's and 00's should be the same. they came out with a new bumper either in 00 or 01... cant remember which. either way...
if the reverse lights on in the trunk bezel, you'll have to unscrew that from the trunk. open trunk, sit "in" trunk and look up. you'll see about 8 "bolts" (think 6 sided screw on bolts) take those off and lift trunk panel off. unplug light harnes. replace bulbs. reverse steps.
as far as the rear turnsignals... i think that the tail light/brake/ and turn signals share the same bulb... i havent had to replace those yet; just the front ones. but you should be able to access those by opening your turnk, pulling the carpet away from the corners and you'll see how many bulbs there are (think only one). then just take it out and replace the bulb.
