Old 01-13-2008, 07:41 PM
michael lambert michael lambert is offline
Paint over polished model
Hey guys,
I have painted and polished my body however found a couple of spots that seem alittle light on the paint can i paint over the polished finish??
Old 01-14-2008, 05:42 AM
wouter1981 wouter1981 is offline
Re: Paint over polished model
I think you can. Just make sure you was it verry good before laying another coat over it. Have you waxed the body? Because I think it's a different story then. i wouldn't recommend that.
Old 01-14-2008, 10:08 AM
Enzoenvy1's Avatar
I would say that you should rough up the area or even the whole model with a high grit around 3200 or 4000 to remove the smooth shine and texture. You want something that the paint will adhere to. The reason I said maybe the whole model is you might see the additional paint even after you re-polish the areas.
Old 01-14-2008, 11:01 AM
klutz_100's Avatar
Originally Posted by michael lambert
Hey guys,
Originally Posted by 360spider
Yes, just make sure you wash it with dishwashing liquid, rinse real well, and let air dry overnight.
http://www.automotiveforums.com/vbul...52#post5600252
Old 01-15-2008, 10:24 AM
Enzoenvy1's Avatar
Originally Posted by klutz_100
I understand that Klutz, but wont there be a noticeable transition from a polished surface to a painted then polished surface? I have seen this happen on real cars before and it looks kind of bad. I was always told to scuff up the surface of the entire panel or part and then repaint it and polish/buff accordingly?!
Old 01-15-2008, 02:48 PM
Didymus Didymus is offline
Depends on what kind of paint you're talking about.
If you're using Tamiya rattle-can lacquer, you don't need to scuff it; a properly thinned new coat will "melt in" to the old. Just clean the area first. I use a soft toothbrush and a highly diluted warm mix of water and CSC. Be sure to rinse it off thoroughly, as you would soapsuds.
Some people - me included - patch an area by lifting the edge of the mask around it. That way you get a feathered edge that will blend perfectly with the coat under it. I think this works better if the paint is decanted and thinned quite a bit with lacquer thinner. That's how I spray it, anyhow.
This is one of the reasons I like to use lacquer, especially clear. It's very forgiving, and when it comes to modeling, I need all the forgiveness I can get.
Ddms
