Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-13-2008, 07:40 PM
DreaminS15 DreaminS15 is offline
B16 Low power real problem
Ok let me try to explain. Was doing about 6k rpm's and heard a LOUD POP.
The engine still runs with no knocking. However very low power. (No smoke in the exhaust)
There is Blow By from the vacuum hose and its not Oil, it feels like Steam.
Oil in crankcase is not milky, water in radiator seems to hold its level.
I have not been able to compression test it yet. Still also looking for a Borescope.
So any ideas of how bad it is? Not sure if a cracked piston, or hole cause would be right because would see smoke from exhaust.
Maybe a bent valve?
Please help brainstorm.
Old 01-16-2008, 11:43 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: B16 Low power real problem
if it was a bent valve youd know it... it would run like shit... maybe timing jumped a tooth??
Old 01-16-2008, 11:25 PM
Yeah I am trying to firgure out the easiest way to deterime if timing jumped, any ideas?
Old 01-17-2008, 05:33 AM
Kind of a Big Deal
pull your spark plugs, manually turn the crank puly counterclockwise until the engine is at TDC. remove the timing belt covers and make sure the mark on the cam gears is lined up
Old 01-20-2008, 10:42 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
why were you redlining your car in the first place ok when its idling and you press the gas does it stumble or hesitate or what does it do when you press the gas
