Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-13-2008, 06:39 PM
ETOH100 ETOH100 is offline
Freebie Mod question
Newbie here with a '99 Blazer 4.3L and am getting ready to install a K&N high flow air filter and was wondering what I might be able to do to the TB or TB plate(and how to do it) while I got it open before attaching the new filter. Also, how do I "disable" the EGR valve and is it a worthwhile mod? What can I do to the MAF sensor/screen to improve performance before attaching the new high flow K&N system? Thanks for the advice and info.
Old 01-13-2008, 09:41 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Freebie Mod question
Disableing the egr will actually hurt your performance unless you use a custom computer tune to tell the ECU to ignor the EGR so leave that alone. Removing the MAF screen is not really worth it unless you are using forced induction. The screen is there to protect the sensor and removing it on a mostly stock motor will only yield a very minimal gain. As for the Throttle plate mod, that will help performance a bit. To do that, remove the plate from the TB (remove the two torx screws, rotate to WOT, pull the plate straight up), cut off the half moon shaped diffusor on the underside, and reinstall the plate into the TB.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
