Old 01-13-2008, 04:37 PM
ben_84_123 ben_84_123 is offline
Exclamation 90 Cavalier Dies when warm Please read
I Tried to solve this on my own but no one else's problems seemed to fit mine, I have a 90 model With the 2.8 ltr v-6 z-24 it was just gave to me because it started acting up last week, before I know its ran perfect for 3 years it was a friends car...anyway
When you run the car til it gets to operating temp it shuts down, sometime it will restart sometimes it wont, even if I drive it say 5 miles then turn it off for more than a cople of mins it wont restart until its cold although a few times its fired alittle like it wants to start when its hot
from time to time it will stutter alittle on cold start but not typically
I have a whole wrecked car worth of engine parts but dont know whats wrong with it, its not the engine itself, its got great compression and vacuum for the mileage it is a pretty high mileage car, 150k+
any idea please let me know
Thanks
Ben
Old 01-14-2008, 05:06 AM
16th hippy 16th hippy is offline
Re: 90 Cavalier Dies when warm Please read
ok, seems to be a heatsoak problem for sure. start with the simple things. fuel pressure regulator...is it leaking when you pull off the vacuum line? does it have a distributor or coil packs? either way, the thermal compound may have dried up over time and not transferring heat like it should. when it won't start, is it getting spark, and fuel?
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-14-2008, 07:38 AM
the regulator is good, I will try to check for fire today when it dies, I do know its not the tcc or the iac, map or maf, thats what I have tested the coil pack is rough to get to...the spark is really strong when it is running tho-
Old 01-14-2008, 08:43 AM
elca69 elca69 is offline
I have a 90 Z-24 with 3.1 in it . I had the same problem that was the crankshaft sensor ( $20 item). Good Luck
Old 01-14-2008, 11:35 AM
muff34 muff34 is offline
yes but has it been checked when it`s a no-go? Have you got it scanned for any codes.
Life Is A Highway ,Enjoy The Ride
Old 01-15-2008, 10:39 AM
The crank sensor will crack over time from the heat. When the engine is cold,it will be fine. As the engine warms up it expands. Thus your engine will shut down till it cools down again.
Old 01-25-2008, 08:18 PM
anomaly_va_1976 anomaly_va_1976 is offline
These are all possible, but I have seen a bad ECM do this on 2.8/3.1s, both carb'd and injected, and the ECM won't always tell on itself...
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
