Old 01-13-2008, 01:29 PM
wildcat47 wildcat47 is offline
2001 2.4 wont start
have dodge caravan, listed above, wont start, have fire and fuel pressure seems to be fine checking shrader valve with pin. any ideas. car died in route to work and have never got it back to run.. had camshaft sensor code and replaced camshaft sensor but no luck. cleared code from system and tried to restart and code is not back..
Old 01-13-2008, 04:36 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2001 2.4 wont start
Reinspect your cam sensor installation. Non OEM sensors have been known to be garbage. What code # did you see? If you have fuel and spark the ASD relay should not be involved but, you might consider reseating/tapping/swapping/replacing it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-13-2008, 08:54 PM
thanks, ill tell my friend whose car this is.
Old 01-13-2008, 08:57 PM
i should have added that he said his check engine light had been on for a long time. so i told him that the code he has could be an old code, he used my scanner to clear the code.
Old 01-13-2008, 08:58 PM
one other thing, i have a fuel pressure gauge, but can you tell me what the fuel pressure requirement is for this car.
