Old 01-13-2008, 12:51 PM
jimtylee jimtylee is offline
Escort mk2 track control arm
Hi,
Does anyone know if i can replace the track control arm by just removing one side of the anti roll bar...instead of taking it right off as i used to do..guess it will be a pain to retension back into the control arm though
thanks jim tylee
Old 01-13-2008, 09:59 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Escort mk2 track control arm
Is it an English MK II escort, the RWD one, or an English/American Escort, based on the Mazda Famila/323/ford lazer thats FWD?
Old 01-14-2008, 07:09 AM
Its a English mk2 escort 1300cc..rwd
Old 01-14-2008, 10:02 PM
Moppie's Avatar
Master Connector
Sweet!!
I used to crew on a Mk1 rally car, talk about an easy car to fix
By track control arm I take it you mean the lower control arm on the front suspension?
Yes you can remove it with out taking off the roll bar. Try it and see what happens. The arm should drop out the bottom, and let you slide it back off the bar. (which for those not familiar, it works as a trailing link).
Not many MKII's left in the world, where are you?
Old 04-19-2008, 06:29 AM
Sweet!!
I'm in Thornton Heath, Croydon...............
Old 04-19-2008, 06:30 AM
Moppie's Avatar
Master Connector
So it be real English one then
Did you get it fixed?
Old 04-19-2008, 06:48 AM
Yes ,
Took the front anti-roll bar off completely, and had to string it like a bow to tension it...bit of a struggle....changed all the rubber bushes on the front now, going to do the rear one's soon.......but a bit of mig welding on the rear of sill is first...it would be near the petrol tank and petrol pipe ...might have to remove the tank...not as brave as i used to be..
JIM...........
p.s. i love these old Escorts so easy to work on.....
Old 04-19-2008, 05:41 PM
Moppie's Avatar
Master Connector
They are great cars, very simple, yet also potentially very quick.
You will be glad to know the fuel tank is very easy to drop out, and nothing wrong with playing it safe
