Old 01-13-2008, 11:51 AM
brandonppr brandonppr is offline
Please help! problem connecting to obd2 port on 1995 cavalier
Ok I bought a 95 Cavalier and I was driving it and the check engine light came on. auto trans 2.2L btw.
When I drive it around town it drives fine, but if I drive it say at 60mph for a while then when I come to a stop it just quits. I can put it in park and it will start like normal. As soon as I put it in gear it dies. even if I give it a little gas and put it in gear it just dies there is nothing I can do to stop it. As long as its not in gear it runs normal and I can rev it or do what ever, I just can't put it in drive. If I wait about 45 seconds it will start up and I can put it in drive and its just like normal.
I took it to Autozone to get the code read. Well there obd2 machine will connect to the port but it will not read the codes. The port is obd2 not obd1. The fuses are fine and the port is getting power. I tried a couple more places to make sure it was not just there machine. still no luck.
I checked to make sure there are no corroded wires or broke wires etc.
What should I do next? I have about gave up
Old 01-13-2008, 01:04 PM
JStumpalump150's Avatar
JStumpalump150 JStumpalump150 is offline
Re: Please help! problem connecting to obd2 port on 1995 cavalier
i thought 95 and below are obd1 and 96 and above are obd2, im not sure but thats what i thought
2002 Nissan Sentra SE-R Spec V w/6 Speed Manual
Old 01-13-2008, 07:12 PM
I thought the same thing, but apparantly they changed them in the middle of 95
Old 01-15-2008, 02:46 PM
dws4wdr dws4wdr is offline
brandonppr.... I'm having the same Issue with my Snapon Scanner. My 95 has a ODBII connector but when I use my scanner I get mis communication erros. Were u able to pull ur codes?
Old 01-15-2008, 03:20 PM
Here is where I am at so far. I have been told that it has an obd1 computer and an obd2 connector. So an obd2 scanner won't work because its not an obd2 conputer and an obd1 scanner won't work because it doesn't have an place to hook it up.
The solution I am about to try is to rent autozones obd1 scantool and jumper it to the obd2 connector. The only alternative is to get an obd1 to obd2 adapter for the obd1 scantool and they are not cheap.
Here is how to do it the cheap way. I have not tried it yet, but I am going to soon.
http://shbox.com/1/xraycable.jpg
Old 01-16-2008, 02:06 PM
yhandor's Avatar
yhandor yhandor is offline
Send a message via MSN to yhandor
Try an OBD1 reader. A few 95's I used my OBD2 on does not work because they are the OBD1
Old 01-17-2008, 10:37 PM
Blue Bowtie's Avatar
Registered Offender
You need a bidirectional scanner. Many 1994 & 1995 GMs used a hybrid PCM that used new architecture but was not completely OBD-II compliant in communications:
Old 01-18-2008, 02:16 AM
16th hippy 16th hippy is offline
hate to send you to a dealer, but the tech2 will work.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
