Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 01-12-2008, 01:37 PM
PUTSKI PUTSKI is offline
2001 300m blower motor
hey masses, anyone replaced their blower motor, not having a fan is brutal.
I have taken the bottom apart and glovebox out to have a looksie but it looks very tight and brutal to take apart
i have checked all the fuses and pulled the heater control panel out to check everything looks ok
if anyone has any ideas that would be great
Old 01-12-2008, 02:11 PM
tinmanwpk tinmanwpk is offline
Re: 2001 300m blower motor
Could be a power module too.
TinMan
99 M Cypress Green, performance rear sway bar, Brembo rotors w/CT3 pads, tint, Sirius, K&N intake, debadged, many other mods.
Old 01-12-2008, 02:15 PM
You also might want to try a recalibration of your A/C:
1. Start engine, don't move car
2. Set temp control to 75 degrees
3. Press and hold the Floor, Mix (vent/defrost) and Defrost buttons at the same time; the floor is a bottom button and the others are upper
4. The control head will blink and give a code. The code will help lead you to your problem.
TinMan
Old 01-12-2008, 02:48 PM
thanks guys I did get a code 36
from the reset I will look it up as I dont have a manual
thanks
Old 01-12-2008, 03:02 PM
Either pull fuse 19 or disconnect the battery a few minutes. That should reset for 36
TinMan
Old 01-12-2008, 03:24 PM
whew thanks I will try that because I cannot find what code 36 is anywhere. I am leanning towards the blower motor is rusted up and needs replacing but I hope not because I did find the job details and its gonna be huge job
Old 01-12-2008, 03:41 PM
k i pulled the fuse and now I have a code 24
hmmmm
Im off to the library for a manual
Old 01-12-2008, 04:47 PM
well code 24 is now gone I found the blower motor and hot wired it and it ran just fine. i checked the one relay and it had power in and out of it to the motor but the motor never spun at all so I am now lost maybe it is the heater control panel that is shot
Old 01-23-2008, 06:32 PM
turns out it was a modual under the dash that is stuck into the duct to help the automatic control I guess. I changed it out and everything is good
Old 01-24-2008, 08:06 AM
Glad it worked out for you. Thanks for the final update.
TinMan
Old 09-09-2008, 09:26 AM
pmpdoutexpo83 pmpdoutexpo83 is offline
ok so i was pretty much having the same problem in my 1999 300m the controls all work but there was nothing blowing out of the vents. so i got the error code and it was 36 so i pulled fuse 19 and now i dont get any error code and there is still nothing blowing out of the vents. any ideas
Old 09-09-2008, 11:11 AM
The only suggestion after all of this is to do exactly what Putski did. If you are handy with a multimeter you can chase down circuits.
TinMan
Old 09-25-2008, 09:32 AM
i was gonna try and change the blower motor resistor would that be the modual that putski is refering to. if not does anyone know where the resistor is.
