Old 01-12-2008, 10:30 AM
Spike2933's Avatar
Spike2933 Spike2933 is offline
Send a message via Yahoo to Spike2933
"WIP" 2007 Audi R10 24H of Lemans Winner
Hi everyone,
with everything ordered I thought I'd start my model now
revell has done a pretty good job with the car, the lines all look right and just a few minor things need to be done.
Red is to cut, Green is to sand down
I've already opened to for the fastners on the top of the car, as the revell mold was just horrid.
I also removed the head cushin using CM PE saws
onto the rear, I've already glued the air ducts and puttied them to make it molded into the cover
you can also see what I have to cut in red.
and Revell does have some issues with the rear cover
one nice thing is I have a nice little cheat cheat
cheers
Steve
Steve
Old 01-12-2008, 03:57 PM
ScaleCentral ScaleCentral is offline
Re: "WIP" 2007 Audi R10 24H of Lemans Winner
Looking good so far Spike. I have been noticing that gap on several people's models of the R10. I've seen a couple of ways to fix it such as adding sheet plastic. I'm curious if it is just bent on most peoples and some heat might fix it. I've gone as far as thinking about putting it in clay to get it to hold in the right spot and casting it. Hopefully I can start my curbside version soon. I will be doing a three way review of the PE sets as soon as I get my KA set. It's looking like KA has the better interior and engine stuff, while Dexter has the better vents, while Studio27 has the better radiator covers/grills.
Nic
http://scalecentral.org
Old 01-12-2008, 05:13 PM
bigfrit's Avatar
bigfrit bigfrit is offline
Nic
I can only add tho his comments, it's going to be a spectacular build, no matter what.
Now to fix the gap (that's also present in my kit, unfortunately) i don't know what will work the best for you. For me, I tried putting it under relatively hot water, bending it a little, as it's quite hard plastic, even for a revell.
It did the trick just a little bit so I d suggest going with that and a little styrene sheet just cut out, and molded in easy with some sanding.
Eitherway, good luck!
Oli
Old 01-12-2008, 09:57 PM
Spike2933's Avatar
Nic
I've seen the first looks from Media Mix, and they also offer PE brake which is kind of pointless since I'm putting the Brake Cooling pieces Dexter has over the brakes, but the pads look very big and beefy to go 24 hours, but it also seems outside of the resin pieces, the PE parts are almost the exact same as Dexters and S27 which just small amounts of other detail
I'm gonna first cut off the extra plastic mold that runs down the hoops, that what, it should give it some more flexiblility, and the real car never has that piece on the rear bonnet. then I would most likely just add styrene strips to make it flush, as that seemed to helped Zuberts Audi
Steve
Old 01-13-2008, 07:28 AM
pawlie's Avatar
pawlie pawlie is offline
Please keep us updated, I hope it turns out as good as your F248!
Old 01-15-2008, 01:14 PM
Spike2933's Avatar
quick update
still working on sanding the body, Revell made some bade mold lines on the body that are suppose to run smooth.
I'm sort of stuck right now as everything is being shipped and should all arrive within 2 weeks (received an Email from Dexter that they only shipped my decals and now will be shipping the PE and resin pieces tomorrow), SMS hopefully has shipped out my order and I got 2 orders from Media Mix that are being shipped out)
I've also noticed Revell has a sort of bad gap
and a quick view of all the pieces
next update maybe awhile from now until I get all my orders
Steve
Old 01-15-2008, 02:03 PM
davesans's Avatar
davesans davesans is offline
Looks good so far so whose silver paint are you going to use on the body?
Regards,
Dave
Old 01-27-2008, 01:33 PM
Spike2933's Avatar
update, but not much on the car.
I got many goodies to share. so here we go.
first is the KA-Models pack. this pack basically will eliminate any need to buy the Studio 27 PE parts as everything you need is in this set and more (the only thing S27 has better than the three companies is the mesh Grilles). This set also comes with some very nice resin pieces: 4 brake calipers, 2 intakes, 2 radiators, and the TV camera. The PE contains alot of stuff, the detail is excellent: the PE set contains, 4 brake disks, belt harness, rear diffuser, rear wing support, rear wing endplates, rivets (from small to Revells premolded), pedals, dashboard, toggle switchs, grilles, Emergency kill switch, tow bars, tail light detail, steering wheel detail (best of any version), mirrors, foot rest, and some others
next is the Dexter Pack, this set is also very nice and has some very nice pieces. The Resin pieces are 4 cooling disks (which cover up the PE brakes ) and the TV camera with antenna (much better than KA's version). the PE that stands out is the side lovours (SP), KA has the whole area to cut out, while the Dexter has just the frame of the lovours. use the Dexter version as that is the only realistic version (KA cut them backwards and they stick out of the body ) of course I did get the presentation plate
the decals were sort of a blessing, Dexter emailed me saying they messed up my order and only shipped out the Decals and the R8 window mask (which I didn't order) well that came and about a week later to my surprise with the resin and PE parts, I got a second decal sheet
well onto the car, I've only CF the front valance of the car and I sprayed the headrest on the car, I've textured the headrest because of reference photos, all I have to do now is add some tape to both sides for the quick release cords
enjoy and I hope the review helps out all the R10 modelers out there looking for some help with the optional detail packs
I need some warm weather so I can finally start painting
Steve
Old 01-27-2008, 02:02 PM
Shunter's Avatar
Shunter Shunter is offline
I look forward to watching this build. I love this car. The resin and PE items look great.
Old 01-28-2008, 07:09 AM
sarge450's Avatar
sarge450 sarge450 is offline
Your off to a great start on this one, looking forward to seeing your progress. One question though where did you get the KA-Models pack? I have the Dexter's PE set, but would really like to add the intakes to the engine bay along with all the other pieces that come with the pack. Thanks.
Old 01-28-2008, 08:24 AM
Spike2933's Avatar
sorry I missed your comment, I'm not sure yet on which silver to whose but I have alot of different silvers to test and see which one is right.
I bought the kit from MediaMix Hobby
http://www.mediamixhobby.com.sg/cata...oducts_id=5498
they unfortunantly sold out very quickly, but when browsing I noticed they added it and quickly bought it, they are a great site and highly recommend their service
Steve
Old 01-28-2008, 06:20 PM
JTninja's Avatar
JTninja JTninja is offline
Very nice CF. Ive never bought CF decals (Im new at this). From looking around I see theres many different types. What ones did you get, and where from? Is only one sheet needed, or more? Also, its it water slide-able? lol
Ive been struggling with the louvers from the dexter kit, Im still on the first grill peice. It wont fit in its slot and stick out at the same time, dont know what to do...might have to use the KA peice....much easier!
Old 01-29-2008, 12:42 AM
Spike2933's Avatar
I bought the CF decals from Scale Motorsport
www.scalemotorsport.com
they are great decals, and are only 8 dollars a sheet, and with careful templetes, you can use alot for one sheet. the decals are water slide, but its also very good to use Micro sol/set, or Solvaset (which I actually like better)
I've yet to take on the side lovours yet, but will be doing them this weekend.
Steve
Old 01-29-2008, 12:53 AM
sarge450's Avatar
Thanks hope fully they will restock the kit soon.
Old 02-03-2008, 10:33 AM
Spike2933's Avatar
quick update from the world's slowest builder
I gave Revell molded seat an extensive rework. here is the stock Revell seat
and the SMS/Dexter Treatment (lookin like a million bucks)
shot at the real thing
onto the wheels, yeah they look abit dull
alittle work and they turn out like this
and the only real other thing I've done is put in the louvers in the rear bonnet
I'm almost done making the 1st of 2 side louvers, I'm working very slow to make sure all the louvers are the correct angle with each other and let the CA glue fully dry before putting hte next one
I hope you all like it, enjoy
Steve
