Old 02-20-2003, 01:34 AM
Mr_Meanor Mr_Meanor is offline
bushing?
I have a 94 s10 with the 4.3. When I make a right turn or more specifically when the weight transfers from the right to left there is a pop sounds coming from somewhere around the tie rods. I orgially thought it had something to do with the tie rods but someone told me its probably just needs new bushing. Has anyone else had this problem and would new bushing fix this problem? Does anyone else know what the problem could be?
Old 02-20-2003, 08:19 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
I had this problem with my 92 fullsize. I checked the front end out and found nothing wrong, I finally replaced the front shocks and the noise dissapeared.
Old 02-20-2003, 10:34 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
3 things to check other than John's suggestion...
1 if it's 4wd check the torsion bar mounts in the rear center of truck
2 the steering stops where the knuckle contacts lower control arm,just pud a dab of grese on the knuckle
3 GM has a coil spring insulator kit to address a similiar noise
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-20-2003, 11:45 AM
SO john you thinks its the front shocks. The shocks on my truck are pretty shot so I think i might give it a try and replace them. If that does not work do you know of anything else it might be?
Old 02-20-2003, 12:02 PM
Blah blah blah
None other than bowtiebandits suggestions. My shocks had at least 100,000 miles on them, and I needed to replace them anyway, and it just happend to fix the popping noise that I had been living with for almost 3 years.
Let us know.
96 Intrepid rack and pinion steering mount bushings ksroadking Intrepid 2 02-27-2014 06:39 AM
Rear torsion rod bushings Infinityman51 Renault 19 0 01-07-2010 06:52 PM
Bush vs Bush Ricochet COMPLETELY off-topic 0 11-02-2004 05:58 PM
Bush is a Soldier!! Vote for Bush!! GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 10-07-2004 03:28 PM
Bush-bashing? THIS is Bush-bashing... carrrnuttt Politics, Investments & Current Affairs 18 08-27-2004 05:18 PM
