| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
tranny fluid
my gears grind every now and then and living in wisconsin, i think its just the tranny fluid being too thick in the cold. i use 80W-90 by the way. i heard that you can use pennzoil's syncromesh cause its thinner. but does is dissipate heat well? i dont want my tranny to blow cause of heat. either that or my syncs' are bad.
Re: tranny fluid
I think syncromesh is a pretty good bet. I'd give it a shot, if its still grinding then better start looking for a new tranny.
Re: tranny fluid
Royal Purple baby. Agree with Thor , when you have a grind new fluids is only a cover up fix and the problem will still be there and continue to get worse. Also if you romp and mash and pop the gears a lot then I would suggest a shock absorbing fluid from a race shop.
2004 Mazda 6i 1997 Tahoe |
Re: tranny fluid
What motor do you have? The 420a trannies cant take anything but stock fluid in them. Anything else can mess up the syncros. Not sure if that applies to the autos.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: tranny fluid
Pennzoil Syncromesh is the recommended fluid for covering up any gear grinding and for harder driving... It's some good stuff...
-Brian
Re: tranny fluid
I use a mix of synchromesh and red line heavy shockproof gear oil.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
