Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-11-2008, 02:13 PM
khienluong khienluong is offline
help on installing shocks
i changed my springs to sportline 2 inches in front and 1.8 at the rear, my shocks are still stock and its bad now and im ready to change it. im thinkin bout gettin kyb shocks and struts, or tokiko..which is better?? what special tools or instructions will i need to know to change my shocks??
thanks
Old 01-11-2008, 05:08 PM
Turbokid15's Avatar
Turbokid15 Turbokid15 is offline
Re: help on installing shocks
I am not to sure on the difference or which one is better, but I do know that you have to remove the tires for the front take the two big bolts out from the spindle then remove the nut from under the hood in the caster/camber plates. On the back remove the bolt from the rear axle then pull the nut off the top. You will have to pull the carpet up a little in the back.
The truck
07 F-350 CC Dually Stroked
Old 01-17-2008, 08:29 PM
so what is a good brand to buy then.. i called kyb but they said they dont have shocks that are compatible wit ma 2 inch drop ... so im thinkin tokico..is that ok??
Old 01-18-2008, 08:27 PM
Pimpdady753 Pimpdady753 is offline
dont forget to do somthing with the springs, dont just jack up the car and undo the strut the spring will take off on u, and ether kill u or someone else. ether spring compresser and compress it just enough so it doesnt go any were, or jack up the control are(i dont like doing it that way tho u still run the risk of it shooting at u)
Old 01-18-2008, 10:27 PM
ok thanks for that advice but im having a really hard time finding a company who had shocks that are compatible with my 2 inch drop in front and 1.8 in rear. what company or brand should i call.???
