Old 01-11-2008, 09:17 AM
sarotara sarotara is offline
Question Need some advice...
I have a 1991 Buick Park Avenue Ultra (non-supercharged) with 140k miles on it. I've had it for about 2 years now and it's a nice car. I've done quite a bit of work on it:
- battery replaced
- starter replaced
- ignition lock cylinder replaced
- rear struts replaced with Monroe Sensa-Trac
- alternator replaced
- ignition coil pack replaced
- transmission cooler replaced
- brake drums, rotors, pads, etc. replaced
- new tires
- all ball joints replaced
- water pump replaced
- pvc valve replaced
- thermostat replaced
However, right now the car is beginning to have a number of other issues which need to be taken care of. It would cost about $2000 to fix everything below (a lot of these I can do in my garage, some I can't). All of the below need to be replaced or fixed
- rack and pinion
- front tie rod ends (they're loose)
- front struts (they're making horrible squeaking noises)
- all brake lines and brake proportioners (they're rusted over)
- intake manifold gasket (getting oil leaks from under it)
- timing chain (about time to do this)
- exhaust system (catalytic converter to muffler (inclusive)) (looks like catalytic converter fell apart inside due to rust, there is a lot of rattling noises from the exhaust system in certain rpm ranges)
- blower motor (rattling and grinding)
- trunk water leak (water probably coming through back window)
- engine or transmission mounts (car jerks when accelerating from red light or stop sign) (could it be the transmission going out?)
I believe the car also has a rear main bearing seal leak. It's slow, but it's there. Very expensive to fix and I can't do it myself.
Anyway, the question I have for you guys is whether I should get rid of this car and buy a new used one (I have about $6k to spend and I was looking at a 2001-2004 Chevrolet Impala or Mitsubishi Galant) or spend the $2000 fixing everything (besides the rear bearing seal) that's wrong with this one. I'm not sure what to do since if I spend money fixing my Buick and the rear bearing seal fails catastrophically or the transmission goes out then I will have wasted $2000 on the car. However, if I buy a used car I'm buying a car that could have potential problems (I know the Impalas occasionally have transmission problems). Please help me decide!
Old 01-11-2008, 01:52 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Need some advice...
Let's say, you invest 2K in miscellaneous parts for the PA and then transaxle fails, of course your 2K is wasted; unless you spend another 2K, for a complete rebuild! Now, if that were to happen, you would have 4K invested in a 1K car!!! Only you, can be the judge of whether this is a wise decision for you to make. Remember, most used cars need some preventative maintenance before they are road worthy anyway, and all used cars (without a warranty) will have cost associated repairs as they are driven and mileage goes up. This decision could be a “coin toss” in my opinion. Sometimes you win, sometimes you lose!
