Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 01-11-2008, 02:56 AM
jtorr2 jtorr2 is offline
Exclamation Front End Vibration
A couple of weeks ago i noticed a slight vibration in the front in at certain speeds. I had the wheels rotated and rebalanced that did not solve the problem my mechanic noticed that i have some burn marks on the front driver side brake rotor. The car shakes rather violent and then it is gone but it only reacts at speeds of 45 to 55 mph. It isn't even a consistant thing it comes and goes and hits at different times and varys in strength if any one can give a thought or has had the problem before any advice would be of some help
Old 01-17-2008, 06:25 PM
Bear Bear is offline
Re: Front End Vibration
You do not give us year and model, however, the upper control arm bushings (thrust) are notorious for wearing out around 70,000 miles and the condition you describe fits with those bushings being toast.
Old 02-14-2008, 11:46 AM
lincolnmaster80 lincolnmaster80 is offline
As bear said, upper control arms (also called thrust arms) are one factor. Tie rod ends can also cause it, and lower control arms can cause it too. Upper strut mounts both front and rear, rear dog bones, rear subframe mounts can cause it. This shimmy is feedbacked through the steering wheel. Unless you have vibration not felt through the steering wheel, then you may have a warped rotor.
1990 E32 750iL --> Pictures
Production: 02/1990
Johan and Sean's E32 Page - Repairs and How-to's
E38.org - Information and tech tips for BMW's
Shogun's E32 Tech-Tips
Gale's Repair Page
ETK Online
Old 02-19-2008, 09:27 AM
Terry Sumner Terry Sumner is offline
We just had this very same problem with a customer's 2001 740il last week.
While bushings may be the problem, the clue here is the burn marks on the rotor. This indicates the rotor has overheated, which can only be caused by contact with the pads. So this tells me that you probably have a sticking caliper or bad flexible brake hose to that side.
Get the caliper off the rotor and try to compress the pistons. If they won't compress, try cracking the bleeder. If the caliper will compress after cracking the bleeder, it's probably the hose. If it won't compress upon cracking the bleeder, the caliper is stuck and you'll have to replace the caliper.
These calipers are hard to find aftermarket if you don't want to pay for new ones from a dealer. I found a pair at autopartswarehouse.com
Terry Sumner
Service Manager
Bergeron, Ltd.
Specializing in BMW
Old 02-19-2008, 11:31 AM
http://www.autohausaz.com also have some good deals on parts. I live in Canada and they are still the cheapest by far!
Production: 02/1990
Gale's Repair Page
ETK Online
