Go Back   Automotive Forums Car Chat > Ford > Commercial Trucks
Old 01-11-2008, 01:19 AM
anomaly_va_1976 anomaly_va_1976 is offline
Exclamation 89 B-700 Exhaust Problem -- HELP!!!!
Hi all ---
89 Ford B-700 (read: Long Frame F-700 with a bus body) , 429-4V...
The problem I'm having is that the driver's side exhaust manifold cracked (I understand this to be a common problem with 370s and commercial 429s) -- Bought a new one (from A-1 Auto over the InterNet if anyone needs one, about $90 each) and when I removed the old one, five of the studs broke off in the cylinder head....
Does anyone have any ideas on how to get them out? I can't put the new manifold on until I fix this. Fortunately, I don't HAVE to have the thing fixed right away, it's being used as a mobile surveillance office. Any help would be greatly appreciated.
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 09-20-2008, 02:46 PM
rhandwor rhandwor is offline
Re: 89 B-700 Exhaust Problem -- HELP!!!!
If they're broke off flush I have center punched them. And used a 5/16 inch drill bit. I then used a 3/8 inch tap and retapped the hole. This is assuming cast iron heads and 3/8 inch studs or bolts. If you have something to work with I soak them with P-B Blaster and use a stud remover,tap good with a hammer before starting. Some people use a thick steel washer with a hole about the same size as the broken bolt use a mig welder and fill with weld. Then weld a nut on the washer and remove. I have tried to drill a small hole and use an easy out but have had them break which causes a worse problem.
Old 09-23-2008, 07:55 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I agree here. You should assume the broken studs are really stuck and an 'easy-out' will break too.
I have seen mechanics use an oxy-acetylene torch and a wet rag to heat up the cast iron surrounding the broken stud, which helps loosen it up and the head can be removed.
IMO if there are that many broken studs, it might be easier to remove the cylinder head and take it into a machine shop so they can remove the studs.
