Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-10-2008, 09:17 PM
dh271 dh271 is offline
Send a message via AIM to dh271
2004 Overdrive
I just bought 2004 Impala this week. It has the 4-speed overdrive. Is it best to leave it in the overdrive position in slow city driving or is the "3rd gear" position same as regular drive?
Old 01-11-2008, 02:46 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 Overdrive
You an use 3rd, which is like direct drive, in driving under 45, I do this a lot.
Old 01-11-2008, 04:56 PM
Re: 2004 Overdrive
Ok, I did that last night and it did great, Thanks!
Old 01-12-2008, 05:45 AM
impalalover impalalover is offline
Re: 2004 Overdrive
what difference did you find by just driving in 3rd instead of 4th with overdrive,i found mine harder on gas and when you go over 45-50 you have to put her in 4th anyway or she wont go into overdrive and will be holding back and be harder on gas
Old 01-12-2008, 10:57 AM
phewop118 phewop118 is offline
Re: 2004 Overdrive
By keeping it in 3rd, you are keeping your transmission from shifting into 4th and back into 3rd, which it will do alot if you are driving between 35-40mph (depending on axle ratio, could be a bit above 40). This helps the transmission by saving it from shifts and it makes the car more responsive because it doesn't have to downshift from 4th to 3rd for hills or slight acceleration.
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
Old 01-12-2008, 12:23 PM
Re: 2004 Overdrive
yes i agree with that but it will still burn a lot more gas then it normally would
Old 01-13-2008, 09:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2004 Overdrive
I agree. Unless you are smarter than the PCM module it is best to leave the shifter in 4th - OD and let the powertrain management system do the work for you even in most city driving, especially for overall fuel economy. However, it doesn't hurt to manually downshift to 3rd in hilly/mountainous terrain or when you need the responsiveness. The other feature the autotransaxle has is the torque convertor clutch (TCC) will lock up at speeds above approximately 45 mph for additional fuel economy. The TCC will only lock up in 4th - OD. I seriously doubt you will get better overall fuel economy just by leaving it in 3rd.
Timeslip 08/12/06
AF Community Guidelines
