Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-10-2008, 08:55 PM
tsi4444 tsi4444 is offline
Boost Problem
I had my manual boost controller set at 15 psi. I had not drove the car for a while and when i recently took it out, the boost was spiking out of control. I checked all of the vaccum lines for the boost controller and they all seem to be fine. The t-fitting is not leaking. I even blew into the line going to the wastegate and it would not let air go through so i would assume the wastegate is shut. I also put in a new boost controller that my friend had lying around to make sure that mine wasnt broken and that did not fix things. So do u guys think that maybe my wastegate is stuck shut? What do u reccomend i do?
Thanks in advance
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 01-10-2008, 09:25 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Boost Problem
So before you were getting a solid 15 psi all the way till redline? Are you sure it's boost spike and not creep? The 16g creeps alot for me. I did have it set at 15psi and by redline it would just creep up to 20psi. So I just compromised and set my boost to 20 psi.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 01-10-2008, 09:47 PM
Re: Boost Problem
No its deffinatley spike. Its allways creeped past 15 towards redline. But now it just shoots way past 15 immediatley and the boost controller is tightened all the way.
97 TSI AWD
Apexi N1
Old 01-10-2008, 09:52 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Boost Problem
Does the wastegate ever open or do you let off before the boost stops raising. Make sure the vac line connections are still on and also test the wastegate with an air compressor to make sure the wastegate isin't stuck shut.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-10-2008, 10:18 PM
Re: Boost Problem
Ive checked all of the lines to make sure that they are connected and ive always let off while the boost was rising. How would i check the wastegate with an air compressor?
97 TSI AWD
Apexi N1
Old 01-11-2008, 09:14 AM
Holset powered 420a
Re: Boost Problem
Put about 15-20psi into the vac line going to the wastegate and see if the wastegate opens. It may have gotten stuck shut while the car was sitting.
98 Eclipse GS Turbo
2001 BMW 325i - DD
