Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-10-2008, 09:54 PM
jlytenth jlytenth is offline
2002 Explorer 4 Dr, Code B2292, 4.0 Eng
Have a code B2292 , air bag light flashes 34, what can be the problem, any help would be appreciated.
Thank You
Old 01-10-2008, 10:14 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 Explorer 4 Dr, Code B2292, 4.0 Eng
A Lamp Fault Code of 34 and B2292 diagnostic code both indicate Safety Belt Pretensioner Status (Passenger Pretensioner Circuit Fault).
Per the factory service manual...
Possible Causes:
A safety belt pretensioner status fault can be caused by:
-Wiring, terminals, or connectors.
-A faulty pretensioner.
-RCM.
-Rod
Old 01-10-2008, 10:34 PM
How would I determine whats wrong, or what is #1 fault for this code.
Thank You
Old 01-11-2008, 07:33 PM
shorod's Avatar
SHO No Mo
I'd start by checking the wiring, specifically the connectors near the pretensioners. Make sure one didn't get pulled loose or end up with a pinched wire. Do you know the history or this Explorer, or did you buy it with the issue?
There is also a specification for the resistance through the pre-tensioner if I recall correctly that may have you determine if the pre-tensioner itself is faulty. I don't have the service manual with me currently though.
-Rod
Old 01-12-2008, 12:53 AM
shorod's Avatar
SHO No Mo
I don't find a resistance spec for the pre-tensioner. Looks like the amount you'll be able to test without special tools is limited to inspecting the connections under the seat and at the seat belt buckle/pretensioner assembly.
-Rod
