Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-10-2008, 09:08 PM   #1
gw84
gw84's Avatar
Send a message via MSN to gw84
problem aiming headlights
I installed some used headlight....last year...and never really got them aimed right. The passenger side one seems ok, but the drivers side is causing some trouble. Whenever I would turn the 'knob' to adjust it, nothing would happen...it feels/sounds like the threads or whatever they are are stripped. I've tried aiming this light so many times that finally I somehow broke the head (where you insert the tool to adjust it). Is there any other way to aim these lights or is it likely stuck where it is? thanks!
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 01-11-2008, 02:51 AM   #2
16th hippy
Re: problem aiming headlights
if the threads were already stripped, then it is stuck where it is. you might be able to find another used headlight assy somewhere.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
16th hippy is offline   Reply With Quote
Old 01-11-2008, 08:38 AM   #3
gw84
gw84's Avatar
darn! that's what I was fearing. I guess they aren't too expensive though....$15 at the j/y. I was looking for an excuse to go there anyway. thanks for the reply
Old 01-11-2008, 04:46 PM   #4
16th hippy
no prob...take a screwdriver or whatever you used to try and aim that one and test replacement out before buying.
Old 01-11-2008, 07:02 PM   #5
gw84
gw84's Avatar
good idea. thanks!
Old 01-12-2008, 10:20 AM   #6
john51md
Originally Posted by gw84
good idea. thanks!
metal adjust screws threaded into plastic get tight, and break, least take some penetrating oil with you and use it as you try to loosen them up, no sense forcing stuck ones and ruining another light when with a little paticence, they will come loose.
john51md is offline   Reply With Quote
Old 01-13-2008, 03:49 PM   #7
16th hippy
another excellent idea...brain farted on that one! Thanks John.
