Old 01-10-2008, 12:11 PM
sps_sac sps_sac is offline
Weak Subwoofer
I just installed a Kenwwod KAC-X10D amp with a single Cerwin Wega Stroker 104 (10", 4 Ohm) subwoofer in my wife's car and can't get much out of this combination except weak bass and distortion, despite trying different settings and wiring combinations. I suspect that the amp is under powered for this subwoofer, however, it doesn't get hot or blow the 40 amp fuse. Can I get some help or recomendations and possibly if you know an amp that works good with this subwoofer?
Old 01-10-2008, 01:03 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Weak Subwoofer
amp is underpowering it ALOT. The sub's RMS is 2000... that amp put out 300rms.... also, what kind of enclosure is it in. If the box is to big it will have very little output.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 01-10-2008, 01:55 PM
Re: Weak Subwoofer
The car is an MB SL500 (two seater with rag top) and I took out the Bose subwoofer which was in a plastic box behind the driver's seat. I had to add a few inches of height to the compartment lid to fit in the 10" subwoofer, and it's not completely enclosed, but that's the only spot I had. The old Bose subwoofer was so bad/quiet, we didn't even know it was there, until I started looking for a location for the new subwoofer.
Old 01-10-2008, 02:08 PM
pre98zetec's Avatar
Re: Weak Subwoofer
From what I understand you're saying the sub is not in a box... That's not a IB sub and it NEEDs to have its own enclosure.
-Josh-
Old 01-10-2008, 02:51 PM
Re: Weak Subwoofer
I can completely enclose the subwoofer if necessary. The final dimensions of the enclosure would be 16" x 14.5" x 11" = 1.48cf. What amp would you recomend for this subwoofer? I think I'm going to have to swith out either the amp or the subwoofer. Which would be the better choice.?
Old 01-10-2008, 03:08 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Weak Subwoofer
CV's need a ported box. If the box is not airtight (except the port) and the car is a rag top (no solid roof), I doubt you will have any bass to speak of. Which one to keep really depends on how much bass you want and the sound quality, also the load on the electrical system.
Old 01-10-2008, 03:42 PM
Re: Weak Subwoofer
The enclosure could be made to be airtight and then ported. Size of port? The car is a rag top in the summer and hard top in the winter, but I have to hardtop off now because of the installation. The rest of the system is working great with XM radio: Kenwood KVT 819 DVD with 6.5" Poly Focals in the doors and infinity Kappa tweeters in the dash. Just doesn't have much bass, it needs more, and I would prefer to have the option to turn it up a lot when I want to, but it doesn't need to bounce the car down the street. I'm sure I can sell either the amp or subwoofer. It would be good to stay which a 40 amp load, which probably means the subwoofer should go. What would be a good subwoofer for this configuration?
Old 01-10-2008, 03:56 PM
new2mitsu new2mitsu is offline
Re: Weak Subwoofer
if the box is ported the dimensions you have listed will be too small, i believe. you could try sealed...
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 01-10-2008, 04:19 PM
Re: Weak Subwoofer
I thinking about replacing the Cerwin Wega 10" Stroker with a JL 10 W3V2-D4 (300 W RMS) and then sealing up the box. Any thoughts?
Old 01-10-2008, 04:26 PM
pre98zetec's Avatar
Re: Weak Subwoofer
sounds like a better idea, that sub is better matched for the amp.
-Josh-
Old 01-10-2008, 04:59 PM
Re: Weak Subwoofer
Porting? 2 rounded 4" ports? Any advice?
Old 01-10-2008, 05:09 PM
pre98zetec's Avatar
Re: Weak Subwoofer
with your space. sealed will be your best option.
-Josh-
Old 01-10-2008, 05:34 PM
Re: Weak Subwoofer
Josh,
Thanks for the help.
Steve
Old 01-10-2008, 06:37 PM
Audio Guy
Re: Weak Subwoofer
hat stroker is a big SPL sub. The bass guys in here would know better options than I would.
Old 01-14-2008, 10:42 AM
Re: Weak Subwoofer
Just installed the 10" JL 3V2-D4 with the Kenwood amp in a sealed box of around 1 cf and it sounds great, plenty of bass. Thanks, Steve
